Hi all,
I have been thinking about making my own loop for a while but there was always sth else with higher spending priority. Today is the day though and i need some advise on compatibility.
My old Aurora with AIO CPU loop died after 11 years of faithful service and i am building a new workstation for both work/fun.
The case is Lian Li O11D XL ROG. I intend to use to 360 rads (top/bottom) with Lian Li O11D distro plate. The rads are EK CoolStream SE 360. For now I will block CPU and GPU inlet/outlets as I have fan assisted cooling in place. I will probably upgrade later. To block these I intend to use EK Water Blocks EK-CSQ G1/4 plug x4. Tubing will be XSPC PETG 14/10 with EK Quantum Torque HDC G1/4 14mm ht fittings x8. Fans are EK Vardar X3m 120mm x6 for rads and one more at the back of the chassis. I will use premix CryoFuel as coolant for now.
It all looks compatible to me but I would appreciate any additional insight from more experienced users.
The rest of the build:
3960x Threadripper
EVGA 2080Ti FTW3 Ultra
ASRock TRX40 Creator
Corsairs HX1000i
Noctua NH-U14S TR4
Vengeance LPX DDR4 4x16 3200
Thanks!
3960x Threadripper
Corsairs HX1000i
Noctua NH-U14S TR4
Thanks!
