Ok, so this is the build I'm pretty certain on, can you check if it is all compatible and will run smoothly, thanks! ![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Intel Core i5-4670K 3.4GHz Quad-Core Processor
Asus MAXIMUS VI IMPACT Mini ITX LGA1150 Motherboard
Corsair Dominator Platinum 16GB (2 x 8GB) DDR3-1600 Memory
Samsung 840 EVO 250GB 2.5" Solid State Disk
EVGA GeForce GTX 780 3GB Video Card
Corsair 250D Mini ITX Tower Case
Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
Microsoft Windows 8.1 (OEM) (64-bit)
Do you think I should get a custom corsair CPU cooler, or do you think I should keep it as it is? Is 750W enough for this build and future updates?
Cheers once again![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Cheers once again
