- 24 Jun 2020
First post so apologies if I miss anything out
After an mobo failure on my 13 year old (!) build, I finally took the plunge to upgrade the motherboard and consequently the CPU and memory.
I now own a Ryzen 5 3600, Corsair vengeance LPX (2 x 8gb) and an MSI B450-A PRO MAX. But, the motherboard arrived damaged and I've just returned it. About to order an identical replacement I realised the memory I bought runs at 3600MHz (C18). Nothing was flagged on ************ but I've since found that the board sensibly tops out at 3200-3400 MHz so would need overclocking. Corsair's compatibility checker only recommends the C14 version.
This time around I'm not planning to push heavy games (graphics card is a 5-year old GTX 960), I really just want a quiet-ish machine that allows me to use BIM software and doesn't overheat. But getting some longevity and future-proofing would be good.
My question is should I return the memory too and just settle for adding some 3200 MHz sticks when I order the motherboard, or look at a better motherboard now?
For a similar price point it would be a low-end X570, which sounds like a bad idea and nobody on the planet can find a B550...
