Compatibility Issues
8 Feb 2009
Hi guys,
Very first post and also very first attempt at building a new pc so please forgive any ignorant questions on my behalf.
Basically I am worried about three major things in my set up, the PSU, MOTHERBOARD and CASE. I will list these items that I have chosen now:
PSU = Corsair TX 850W ATX2.2 SLI Compliant Power Supply
MOTHERBOARD = Asus P6T Deluxe Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
CASE = Coolermaster HAF 932 Case - Black (No PSU)
I have just a few questions about these products so please bear with me and once again apologies for stupid newbie questions.
1) Is the power supply I have chosen going to have all or enough of the relevant cables for this set up and is the wattage enough for a ATI 4870 X2 GFX card?
2) The case has 3 standard 230mm fans. Does this motherboard provide enough connections in to connect all 3 and maybe more?
3)I'm slightly concerned about cooling, so has the case I selected going to provide sufficient cooling for the Hard Drive and GFX Card? (I will not be overclocking).
Thanks for your time guys, I appreciate all the feedback you will give as I am itching to order this set up very soon.
And a more elaborate answer......
Corsair power supplies are very high quality, that one inparticular could handle 2 of those graphics cards, nevermind just one.
The case fans are connected to the power supply (which will be fine).
That case has brilliant cooling, one of the (if not THE) best in that price range.
mate thank you very much for your quick response, very much appreciated.
I will list the other part of the set up as well :)
Asus ATI Radeon HD 4870 X2 2048MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) -
Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366) - OEM £233.44
Corsair 6GB DDR3 XMS3 PC3-10666C9 1333MHz (3x2GB) Triple Channel DDR3 (TR3X6G1333C9)
Microsoft Windows Vista Home Basic SP1 64-Bit - OEM (66G-02141)
Samsung SpinPoint F1 750GB SATA-II 32MB Cache - OEM (HD753LJ)
Seagate FreeAgent Desk 500GB USB2.0 External Hard Drive
Belkin F5D8053UK 300Mbps N Wireless USB 2.0 Network Adapter
Sony NEC Optiarc DRU-V200S 20x DVD±RW SATA Dual Layer ReWriter
BitDefender Anti Virus 2009 £16.09
Scythe Kaze Maru 140mm Cooling Fan - 3 Pin £10.34
Fingers crossed that this first attempt will be successful!
i have a 24 inch LG monitor already, and a 40 inch Sony tv that i might hook it up to.
And dont be jealous mate lol the computer I am currently on is a Dell pentium 4 which is around 5 -6 years old. I need a new computer badly and was just peed off with being ripped off by companies so i thought i will give making it a go!.
Once again mate, thank you for your great reply :)
