Compatibility question
24 Feb 2004
St.Andrews
This might be better off in Memory or Mobo's if so can a nice mod please move as needed.
Looking into downsizing the box that holds all my PC bits. Case is all sorted but there are now only 2 mobo's I can see that support what I want.....therefore:
Are there any known issues with G.Skill RAM and the NV NF430 chipset?
/me wanders off to find out how much money I don't have :(
It might be better if you posted the actual motherboard and Ram that you intend to buy/have already. I don't know for certain but I'm guessing that you are using socket 939 from the chipset? If so I can't recall any specific issues with GSkill and socket 939 but someone else will no doubt be along to correct me once more details are added. :)
D'oh! how did I forget :o
Have G.Skill PC4000HZ (sadly is all I can remeber about it right now) and OcUK no longer list it for sale.
Socket wise yes 939 and I was looking at any of the mATX mobo's (all of 2) and prefereably the Gigabyte as it has the slightly better chipset....
