Description:
Offering practical functionality for both home users and enterprises. Combining trustworthy performance and essential features, the V-Series micro-tower is a high-performance PC built with the budget conscious users in mind.
Elegant ID Design V-Series Barebone with stylish appearance is more than just a PC that you hide under the desk. V2 with blue light bar is an art in your life.
Expand Depending on Your Needs Ideal for basic computing to more complex multimedia entertainment, the V-Series provides excellent scalability catering to various user needs. With two PCI slots, one PCI Express x 16 slot, one PCI Express x1 slot and two optical drive bays, system expansion for multimedia entertainment and high-speed computing is a simple process.
Recover Pro - Your Files are in Good Hands Recover Pro is an always-available recovery tool. It stores user data, applications and the operating system in the host-protected area of the hard drive. Users can easily recover system to their original factory conditions or to a more recent state without restore CDs. No need to worry about losing data due to virus attacks.
Anti-Virus Solution ASUS, understanding the importance of data safety, bundled industry-leading anti-virus software to assure your files are protected against outside attacks.
Dependable Quality ASUS subjects its desktop barebone systems through a series of stringent quality tests to provide the very best in performance, stability and compatibility. Even the electromagnetic level is tested and improved to limit interference with other devices to provide a superior computing environment.
Technical Details:
Audio Realtek ALC880,
Audio output 8 Channel Codec
Chipsets North Bridge: VIA K8M890, South Bridge: VIA VT8237A
Cpu AMD Athlon 64FX/Athlon 64/Athlon X2 up to 5000+(89w)
Cpu fsb 1000/800 MHz FSB
Cpu socket Socket AM2
Dimensions 168 x 380 x 354mm (W x H x D)
Drive bays 2 x 5.25", 3 x 3.5" (2 external)
Expansion slots 2 x PCI, 1 x PCI-e x 16, 1 x PCI-e
Front i/o 2 x USB 2.0, 1 x Microphone, 1 x Headphone
Graphics VIA Graphics Integrated
Ide 2 x Ultra DMA 133/100
Lan 10/100/1000 Mbps
Memory 2 x DIMM, DDR2 533/667, Support max. 2GB
Power supply 250 W (PFC)
Rear panel 4 x USB 2.0, 1 x Line-in/Line-out/Mic-in, 1 x PS/2 Keyboard, 1 x PS/2 Mouse, 1 x Parallel Port, 1 x Serial Port, 1 x D-sub (VGA Out), 1 x RJ45 LAN
Sata 2 x Serial ATA I
Warranty 1 Years Return To Base
