'Compatible' Ink Cartridges
26 Oct 2004
Up North
Hi. I've been wondering if 'compatible inks' have improved in the last 6-7 years as the last lot a bought for an old printer messed it up royally! I think I had to get through about 2 more 'genuine' cartridges just to clear the blockages properly! I just seems crazy that you can buy 4 compatible black cartridges for about £5 or one genuine for £20! I'm mainly looking at Epsons but any info on other brands would also be good.
Cheers
I would alternate between the two- The compatible carts have much worse quality ink, & after using them for a while the print quality decreases. Then go back to genuine for a single cart and start the cycle again- Our printer has lasted over 3 yrs doing this.
-Leezer-
