Compatible RTX 3080s/RX 6800xt with NZXT H400i
14 Jun 2021
UK
I've got an NZXT H400i case and I love it. Love the size, look, the lot. But as an MATX case, and with the size of the new gen graphics cards I'm wondering if I'm going to be severely limited.
Tried looking at the dimensions of the case and on PC Part Picker, but it's not always clear if they're compatible or not.
Anyone else have this case and got any insight?
Cheers!
Awesome, cheers! Sounds stupid to check on here but I got burned with my last mATX case and GPU clearance (thought I had got my measurements right) so thought it best to double check. I hope the "height" of the card is no problem in thise case as the new GPUs looks bigger in every dimension.
