Helping a guy with a pre-existing build - he needs to reduce the weight of his PC but silence and cooling is still a priority (he has a toasty 7700K which at present is kept remarkably cool).
He'll be moving from a bequiet full tower and 280mm rad to hopefully (reducing weight by ~7Kg):
The D15 is 165MM and the case max cooler height is reportedly 170mm. The 5mm play is a little disconcerting when factoring in the tall memory.
I realise that the fan on the D15 can be raised slightly or he could even take the tops off his memory - but the latter is not ideal (He would probably choose to move to low profile if the memory had to be customised).
Basically, is there the room - will the above combined case, cooling and memory work together with slight fan adjustment only if required?
Any hand on experience appreciated.
Total Spec:
Motherboard Gigabyte Aorus GA-Z270X-Gaming K5
CPU Intel Core i7-7700K
RAM Team Group Dark Pro 16GB 3000MHz
GPU Gigabyte GeForce GTX 1080 Xtreme Premier Pack
SSD1 Samsung 960 Evo Polaris 500GB
SSD2 Samsung 960 Evo Polaris 500GB
SSD3 Samsung 850 Pro 1TB
PSU Super Flower Leadex Platinum 650W
- Corsair 400Q case (case dimensions and look are important to his needs - carefully chosen)
- D15 cooler
- with existing Team Group Dark Pro x 2 8Gb
Total Spec:
