SilverStone has kindly given me a SFX-L 500W '80 Plus Gold' Fully Modular Power Supply to give away to you lovely users on our forum!
Silverstone SFX-L 500W '80 Plus Gold' Fully Modular Power Supply @ £74.99 inc VAT
For small form factor enthusiasts, the standard SFX power supply form factor has excellent combination of size, power, and affordability. At 100mm deep, however, the standard SFX PSU is also limited in fan size to 80mm. While advances in engineering and components have made modern high-end SFX PSUs quieter than ever, there is still inherent limitation with 80mm fan’s ability to dissipate heat at maximum loading conditions while maintaining satisfactory noise profile for users sensitive to higher-pitch sounds.
With this in mind, SilverStone has released a “lengthened” variation of the SFX form factor called, SFX-L. With 30mm of added depth, a SFX-L power supply has enough room to fit a 120mm fan, thus its maximum load noise can be not only lower in intensity (via slower fan speed), but also lower in pitch (due to larger fan size).
The first model to debut in the SFX-L will be the SX500-LG, a 500W model that includes all features available from top of the line SFX SilverStone PSUs such as 80 PLUS Gold efficiency, modular flexible flat cables, and semi-fanless capability. An ATX adapter bracket is included as well to enable users to install this PSU into any small or even larger cases that do not have SFX mounting holes.
Features
- Silent running 120mm fan with intelligent semi-fanless operation
- Support SFX-L form factor and ATX via included bracket
- High efficiency with 80 PLUS Gold certification
- 100% modular cables
- All cables made with flexible flat arrays
- 500W continuous power output at 40? operating temperature rated for 24/7 operation
- Class-leading single +12V rail with 40A
- Strict ±3% voltage regulation and low ripple & noise
- Support dual PCI-E 8/6pin connectors
- Active PFC
Specifications
- Model No.: SST-SX500-LG - Max. DC Output: 500W - combined +3.3, +5V: 105W - combined +12V: 480W - Input Voltage: 90V ~ 264V - Input Frequency Range: 47Hz ~ 63Hz - PFC: Active PFC(PF>0.95 at full load) - Efficiency: 87%~90%(20% to 100% loading) - MTBF: 100,000 hours - Operating temperature: 0°C ~ 40°C - Protection: Over power protection, Over voltage protection, Under voltage protection, Short circuit protection- - Colour: Black(Lead-Free Paint) - Cooling System: Single 120mm silent fan - Noise Level: 0 ~ 36 dBA - Dimension: 125 mm (W) × 63.5 mm (H) × 130 mm (D) - Weight: 1.4 Kg - Form factor: SFX-L - Certification: 80 PLUS Gold - Other: Includes SFX to ATX bracket for use in ATX case
Connectors
- 1 x 24 / 20-Pin motherboard connector(300mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector(400mm)
- 2 x 8 / 6-Pin PCIE connector(400mm / 150mm)
- 3 x SATA connector(300mm / 200mm / 100mm)
- 2 x 4-Pin Peripheral connector (300mm / 200mm)
- 1 x 4-Pin Floppy connector(300mm / 200mm / 200mm)
- Warranty: 3 Years
Only £74.99 inc VAT.
ORDER NOW
How to enter:
This one to be exact!
In order to enter, you need to do 3 things.
1) Take a photo
2) Include a sign saying "I love OcUK and SilverStone!"
3) Share with us here
We will choose a winner on the 29th June!
Good luck!
PS. SilverStone have also kindly provided a Sugo SG13B-Q to run a competition on Twitter, so if you have Twitter take part here:
https://twitter.com/OverclockersUK/status/613377426484277248?lang=en-gb
Features
- Active PFC
Specifications
Connectors
- Warranty: 3 Years
ORDER NOW
How to enter:
1) Take a photo
Good luck!
