- 28 Aug 2019
I'm looking to build a complete PC system for £2000, monitor included in the price. I'm interested in a RTX 2080, Intel I9 9900k build with a lg 27gl850-b monitor but I dont know what else I should buy
Pulse is a good card. Got a great review from GN. Also, standard GB AMD cards are not amongst the most highly regarded.Pulse is stock PCB and only 2 yr EU warranty .
Gigabyte is 3 yr UK. Also triple fan and 2.5 slot design
My basket at Overclockers UK:
AORUS have the better designed Z390 and no secret that , also UK warranty blows apart MSIs , but MSI do have a slicker BIOS as x570 BIOS hasn't filtered down
If for pure gaming , 9700k ! If your looking for workloads the. Ryzen 3700/900x
I do agree however, that the Ryzen system is a better choice.
Just his chosen cpu and monitor is taking nearly half his budget.It's reference PCB . Might as well buy blower card and alphacool Eiswolf for little more on top.
Gaming OC Vega did pretty well, only card that out matched it PCB wise was Nitro +. Others also had to be Triple fan and triple slot to beat it's cooling .
2 yr warranty is nuts for £450 card.
Mind 2k budget would be pushing 2080RTX for more power
it does not, but to be perfectly frank even the RTX 2080ti only just barely supports it in the current state. All of about 6 games and it hammers the frame rate for a fairly negligible visual bump. Realistically you're better off not bothering with ray tracing just at the momentDoes the RX 5700 support ray tracing?
which is a pity because it could be really cool,it just isn't there with the current hardware or games
I might just go for that ryzen 7 and ex 5700 xt build. If I wanted to upgrade to the rtx 208p and i9, would I need to change any other parts?Thank you for all the suggestionsI might just go for that ryzen 7 and ex 5700 xt build. If I wanted to upgrade to the rtx 208p and i9, would I need to change any other parts?
So I wouldnt need to change anything if I wanted to upgrade to a ryzen 9 3900x and a rtx 2080?I'm not sure you could really call moving from the 3700X to the 9900K a real upgrade, but one thing I can absolutely guarantee with 100% absolute certainty is that should you want to upgrade your CPU in 2-3 years time you'll be able to do so with the build I linked above. If you opt for a 9900K build of ANY form, you're already topped out and you'll need to replace your mobo as well as your CPU.
I've just noticed the tower case and power supply are out of stock, any others you would recommend?You could drop the build below the 2K mark by cutting down to a less expensive SSD and RAM, for the average user an expensive NVMe drive isn't going to show a noticeable difference.
As for the RAM:
- 1 x Team Group Dark T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black/Grey (TDGED4= £79.99
That said, I'd recommend looking into the current AMD chips as you'll get more for your money, although it does depend on what you're using your rig for. Here's an AMD build for reference:
- 1 x Gigabyte X570 AORUS ELITE (AMD AM4) DDR4 X570 Chipset ATX Motherboard= £209.99
- 1 x LG 27GL850-B 27" 2560x1440 NANO IPS 144Hz 1ms FreeSync/G-Sync Compatible Widescreen LED Gaming Monit= £469.99
- 1 x AMD Ryzen 7 3700X Eight Core 4.4GHz (Socket AM4) Processor - Retail= £329.99
- 1 x Gigabyte Radeon RX 5700 XT Gaming OC 8GB GDDR6 PCI-Express Graphics Card= £449.99
- 1 x WD Blue 3D NAND 1TB M.2 2280 6Gbps Solid State Drive (WDS100T2B0B)= £119.99
- 1 x Fractal Design Meshify C Blackout Midi Tower Case - Black Light Tempered Glass= £79.99
- 1 x Corsair RM Series RM650 650W '80 Plus Gold' Modular Power Supply (CP-9020194-UK)= £76.99
Comes under the £2000 budget, so there's room to add more storage, or change in a preferred case, or add some RGB bling if that's your thing. You've also room to swap in a Nvidia graphics card if you've a preference, but I'd personally stick with the 5700XT.
