Completed My Watercooling Setup
17 Apr 2011
In front of my monitor
So after many hours of reading Ive finally finished my watercooling rig.
Specs are as follows:-
Corsair 800d Case
Corsair 850w Modular PSU
Corsair Vengeance Ram (2 x 4gb) CS8
Nvidia GTX590
Gigabyte Z68X UD4 Motherboard
2600k Intel i7 CPU
2 x 2tb Western Digital Caviar Greens
2 x OCZ Agility 60gb SSD's in Raid 0
Lamptron FC5 Fan Controller
Samsung SH-B123L Blu Ray Drive
Water Cooling Specs:-
Coolgate CG-360 Copper Rad
3 x Gentle Typhoon 1450's
Alphacool VPP655 (Laing D5)
XSPC Acrylic Dual Bay Reser
Aquacomputer aquagraFX For gtx590 copper and brushed stainless block
EK-PSC compression fittings x 8
EK-Supreme EN cpu block
Phobya Y-Cable 3Pin Molex
Primochill PrimoFlex Pro x 3 meteres (Blue)
Thermochill EC6 Non Conductive coolant
Phobya LED UV Reservoir lighting
Sharkoon 30cm Cold Cathode kit UV x 4
Ive took a few pics of the build as I went (Sorry for the odd blured shot as they were taken on the old dog n bone):-
Before I added watercooling.
My watercooling order arrives! Boooom!
GTX590 Naked in all its glory!
Time for a spot of 24 hour water leak testing, which turned into a 12 hour ive gotten bored water leak test. Mainly as I never had an initial leak.
looks great! what sort of temps are you getting on the 2600K? and at what clock?
Also, how much did the watercooling specs cost approx?
Thinking about it WC'ing too :D
Great build!
:oFor the case, fans, controller and all WC kit with tools came to a lip quivering £763 pounds delivered. No the missus doesnt know haha
As for temps:-
I run my system at 4.5ghz with 1.315v as my 24x7 clock. This clock is solid as you like, so im more than happy sitting on the fence here lol.
My 3 x Gentle Typhoon 1450's running at 6.1v (720rpm) which is v.quiet.
Idle:- 23 degrees
100% load under Prime 95:- 40 degrees
Did say it was expensive lol.
Could be done for less if you compromise on parts and try to secure second hand bits n bobs. Id say by as much as half if you hunt around for long enough!
This price does include the 800d case dont forget which isnt the cheapest of things to buy along with a gtx 590 waterblock which again doesnt run cheap.
Didnt take air temps as I built it on air and then the next day swapped out to WC within the 800d case.
Looks nice there and such a nice case too. Very nice temperatures as well even if £760 is a bit of an investment :P Wish i could go about getting a project like this ha :)
yeah its a tadge on the excess side but at the end of the day, I spend a lot of time on the old pc.
I can now sit in my office without sweating whilst playing games now haha
To be honest if i had the money to spend id definitely go for the watercooling approach, temps are usually great and they look brilliant.
PS. I also want the blu-ray drive you have :P
Very tidy. Realign your front cover though it's off on the RHS by about 1mm :p
