- 29 Dec 2009
- Germany
This has been puzzling me for ages so I decided to post it here.
What is the actual, physical difference between different CPU types, other than the manufacturing process and size?
Ie. what's the difference between an i7 at 4 GHz and a Core2Quad at 4 GHz? Why does the i7 outperform the C2Q?
Aren't they both just 4 cores that can run 4.3 billion instructions per second?
Also, what separates a CPU core from a GPU core? Why can't you just use existing GPU technology to run regular instructions? Wouldn't that easily allow you to have CPUs with 1000+ cores running at 1 GHz?
What's the difference between CPU instruction types (like SSE2 or w/e it's called)?
And finally, why are CPUs so large?
Okay enough questions for one post, but these have been seriously bugging me.
