I have been having lots of problems with my current build, and have run out of ideas to get it working again. But first, a bit of history...
The system was built about a year ago (AMD Phenom 2 X3 on Gigabyte mobo with 4GB of Corsair RAM), and worked fine from day one. In April this year, I noticed some weird things going on in windows, such as USB devices disconnecting and then reconnecting by themselves. I didn't think much of it. Then one day at the start of May, the system simply would not power on. No POST, no beeps, nothing. It was completely dead.
I went through the usual procedure of cleaning it all out, removing extraneous drives, cards etc. but nothing worked. I first replaced the PSU with a modular OcUK one, but that still did not fix the issue. I then obtained an RMA from gigabyte for the mobo, and sent it back to them. They sent it back with an updated BIOS, saying it was now working. It wasn't. So, I sent it back again, and they sent me 8 pictures of the board working in their lab, thus proving the mobo was working fine.
Now I was getting puzzled at this stage. When i got the board back i did an open install, with no chassis, on an antistatic mat to see if it was a short in my chassis. All i plugged into the board was the new PSU, CPU, 1 DIMM and a switch to power the board on. Even this yielded nothing. I swapped out the DIMM and tried the other one, and that didn't work either.
Now looking like there was only one thing left to try, I obtained an RMA for my CPU with AMD, and sent it back for testing, but guess what? They have sent it back, saying it was working fine.
The only thing left is possibly the RAM, but I would be shocked if both had died at the same time. The system has not been overclcoked, everything was running stock speeds, and temps have all been fine, so I can't see it being related to that either.
Does anyone have any ideas or suggestions?
Thanks for your time.
I will try bridging the wire and see what happens..
