System Specs:
I only want to overclock the CPU it up to 4.2GHz
Would you guys recommend using Asus TurboV Evo for overcloking? If yes, then using software do i just increase the CPU ratio or do i have to mess around with the voltage etc?
Screen of TurboV Evo which gives me those options:
Edit: Wrong section.. mods please move to overclocking section. Thanks
- Asus Sabertooth Z77
- Intel i7 3770k
- Corsair 16GB DDR3 1600 MHz CAS 10 XMP Dual Channel
- 650D Case
- AX 750 PSU
