Completing my build :)
30 Dec 2008
Okay on tuesday all my components arrived and I built my first pc.. Since then I have had no mouse and no proper monitor (was temporarily using 32" TV and sister's keyboard).
I've chosen this keyboard: http://www.overclockers.co.uk/showproduct.php?prodid=KB-145-LG
But I'm a bit unsure on the monitor. I know I probably want a 22" and will probably want to buy another one in a few months of the same kind..
I've been looking at the ASUS on OcUK and the Samsung T220 (173GBP delivered from competitor).. I like the rose models, tint of red is good for my room..
Any help is always appreciated...
Well if youre thinking of dual monitors youre obviously ok for space, so Id say spend a bit more and get a 24" one like this samsung
Ah hey again, you helped build my spec.. I'll post up some pictures when it's all good and done if you're interested..
So a 24" to replace them? I have been using a 32" TV and its absolutely huge.. I hate how big it is and fear I'll do the same again if I go bigger than 22". I can't really envision the sizes on my desktop, especially as I'm currently not at it and wont be for a while.. Either way I think 22" is better, as I need space to do things on my course that don't require a computer.. drawing, annotating and such...
Edit: Changed my mind... got the T240.. Might be a while before get my hands on money for second monitor, plus I see most people spec themselves 24" so can't be too over bearing. So thanks for advice, and thanks OcUK for the deal, It's definitely what topped the decision between you and a competitor... Nice coincidence in fact..
Love the style of these samsungs :)
