Hi
I have an LCD TV i would like to wall mount at one end of my living room. The wall in question has on the other side a large walk in cupboard. What i'd like to do is drill a small hole through the wall and feed the cable through to the cupboard side. That way there'd be no cables trailing from the TV and i'd be able to have a media PC connected in the cupboard.
The difficulty is that i'd like to the hole to be as small as possible to limit damage to the wall. A DVI connection is over an inch wide, where as the DVI cable and power cable combined would be less than half an inch. Removing the plug from the power supply is obviously a simple matter, the DVI not so.
How complex is a DVI cable? Would there be any way to reconnect a severed cable if i cut it? Or perhaps there's an easier way?
Thanks in advance.
(i considered placing this in Home Cinema but this is more hardware related, or even electronics)
Thanks in advance.
