Component advice for a PC build (novice)
13 Dec 2016
Hi All,
Firstly Im not a gamer but I am going to build a PC for photo editing but I would like to build it in such a way that if I decided to try gaming it would work for that also. These are the components I was thinking off. Its a small form factor as I don't have much space at home.
I already have a i7 6700K processor which I got from a friend that works for intel.
(1)Cooler Master Elite 130 Case “RC-130-KKN1, USB3.0, Mini-ITX, 120 Radiator Support
(2)ASUS Z170I Pro Gaming Motherboard
(3)processor cooler? Need advice on this. Something that would be good if I decided to overclock.
(4)ADATA Premier SP550 480 GB 2.5 Inch SATA III Superior Read & Write up to 560MB/s & 510M​B/s Solid State Drive
(5)INTEL SSDPEKKW256G7X​1 SSD/600p 256GB M.2 80mm PCIe 3.0 x4
(6)Ballistix Sport LT 16GB Single DDR4 2400 MT/s (PC4-19200) DIMM 288-Pin Memory
(7)Corsair CP-9020090-UK RM550X 550 W ATX/EPS Fully Modular Power Supply Unit
(8) GPU? need advice. Nothing to extreme to start with just incase I don't get into gaming in a big way.
Any help would be much appreciated. Thanks for your time.
Thanks all for the advice. The 1060 seems to be within my budget. Will this fit the case I have chosen and also can you suggest a CPU cooler that will fit and will suffice overclocking of CPU in the future.
The 1060 comes in a few flavours, a 3gb or a 6gb version, and of each there are small single fan mini versions, or versions that are longer with 2 fans. So maybe the mini...
