- 19 Jul 2020
Looking to build my 2nd PC as my current one is getting old. I do average level gaming and general use including occasional Adobe CC use (Photoshop, Illustrator & XD) Primarily shooters: Call of Duty, Forza, Minecraft (Modded & w/ Shaders) and some fortnite
Im looking at roughly £800 with some leeway (NZXT H1 case included in budget. costs $349 on their .com site)
Am planning on building within the next few weeks before my bday (unless there are specific next-gen components coming out in the next month or two that's *really* worth waiting for.
The components I'm after (and would like recommendations/advice on are:
Appropriate ITX motherboard, compatibie CPU, GPU and RAM (ideally 16GB) and potentially an M.2 SSD
Case comes with power supply & CPU cooler
could potentially use my exisiting SSD for OS/games library if buying a new M.2 SSD (for OS) eats into the budget too much
I'm not planning on overclocking and my only requirements are:
Motherboard with decent onboard wifi capabilities (attachable arials welcome) as existing PC has poor connection
compontents that are compatible with each other & work together (not sure how common bottlenecking is these days)
Aesthetic wise, I'll be using the mini ITX NZXT H1 case, black/dark components are preferred, I'm going for a sleeper/covert look so not bothered about flashy compontents
Essentially just looking for components that'll be the best bang for my buck, that will handle average 1080p 60fps gaming at 60hz. Any future proofing would be awesome too
Any advice is welcome, has been 5-6 years since I built my current PC and am not particularly up to date with new compontents and what works best together.
My current pc does use an AMD rx480 - and this * could* be carried over if it would manage my usage but I'm not sure it can, the CPU and motherboard in my current build are certainly struggling, and I'm looking for something smaller and sleeker, hence the new build, any advice would be great!
Sorry for the long post! :/
