COMPONENT AV Multi Switch Box
Ive had one for years and cant see any loss of picture quality good thing about it is it doesnt require a power supply its just a simple switch box.
Cheers for that fella, just what I wanted too hear :)
is the component connection better than typical scart , ie gamecube and ps2 normal connections?
can you get component for those 2 consoles if it is better ?
Component gives much better picture quality than standard scart and RGB scart.
I'm not sure if you can get component for those consoles unless there's such a thing as a scart to component cable.
