My HDTV does not have a direct component input, but as component has a similar cable system to VGA, so the TV will accept a component signal via the VGA port. The TV itself has 2 separate channels for that connection, PC and YUV.Sclodion said:I thought VGA required separate signals for H-sync & V-sync so you would not be able to take the RGB signals into a VGA connector and expect a picture? If thats what you're doing on your 360, can you provide a bit more detail on what you're using, i'm intregued.
I dont know much about the Wii, but what form does the component take? is it RGB or YUV?
Some (not all, not that many either) TV sets accept component via the 15-pin D-sub connector, no conversion needed, the TV recognises it is a component signal.Sclodion said:I thought VGA required separate signals for H-sync & V-sync so you would not be able to take the RGB signals into a VGA connector and expect a picture? If thats what you're doing on your 360, can you provide a bit more detail on what you're using, i'm intregued.
