Hi,
Im currently running an ageing socket 939 winchester 3000, which is in desperate need of an upgrade, so this is what i have come up with. I only have about £200 give or take £50. All of the other components will be reused from my current system.
I am fitting only a single 2 gig stick of RAM as i dont have the money for 4 gig, but still want to have the option to add another stick later if needed.
Intel OEM 8300 processor
Gigabyte GA-EP43-DS3L Mainboard
1 X 2 gig Corsair TwinX PC 8500
Arctic Cooling Freezer 7
What do you think of the components? Anything I should change?
A few questions about this setup
1 It seems as if this will work fine on my Enermax NoiseTaker 485watt PSU as it is still only taking the 24 pin and 4 pin connections. Is this correct?
2 Is the upgrade to Vista (32) a worthy one yet as I am still running on XP and am quite happy with the way it is performing. If I did "upgrade" to Vista would the system performance actually decrease?
3 Would I also need to get thermal paste for the cooler or is it supplied?
4 I am fitting an old 6600 GT PCI Express graphics card to it. Would there be any problems running this in a PCI Express 2.0 port?
Thanks very much for the help
