Hi All,
Im looking to upgrade my PC...
-Athlon 64 4400 Dual Core
-DFI LanParty UT NF4 SLI-D
-2x1GB OCZ PC3200 Platinum
(yes its been a while!)
I only need to upgrade these 3 parts. So forget anything else especially GFX card (which is an XFX 8800 GTX 768 at the moment)
I was looking to do a cheap upgrade and was looking at this...
-Asus P5Q Intel P45 (Socket 775) PCI-Express DDR2 Motherboard
-Intel Pentium Dual-Core E5200 "LGA775 Core 2" 2.50GHz (800FSB) - Retail
-Kingston HyperX 4GB (2x2GB) DDR2 6400C4 800MHz Dual Channel (KHX6400D2LLk2/4G)
-Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Which totals to only just over £230 inc VAT.
I am looking at this combo because a friend of mine has the same spec and hs clocked the CPU to 3.85 Ghz!!!!!. Compared to my current spec it will fly.
But im wondering if i should spend that little bit more and get DDR3 or anything. Or get a X48 mobo (im not interested in SLI though). Or get the Intel Core 2 Duo E8400 LGA775 'Wolfdale' 3.00GHz (1333FSB) - Retail CPU.
Not sure really. What do you suggest?
Thanks all.
D.
Thanks all.
D.
