Evening folks,
I'm currently in the process of upgrading my system but I need a little help in regards to what I should get.
Currently I have Coolermaster HAF 932 case which is pretty good as it's the ideal size for me as it will be sitting on a desk, however I wonder if I can do better.
What I would like is a case that:
a) will allow good airflow as I plan on going crossfire and the room can get quite hot
b) I would like to use an all-in-one water cooler for the cpu so any advice on that would be good but the H80 or the H100 are the ones I'm looking at if that makes a difference
c) Only one Blu ray drive will be installed so only 1 optical drive space is required
d) I'll require space for 3 SSD drives and 1 normal hard drive
e) I'd also like the case to have USB 3
As for the motherboard I plan on having crossfire and a sound card so enough PCI Express slot space is a must.
Any recommendations are appreciated
