Components to match
27 Mar 2016
Bristolian living in Swindon
Hi all
On payday (Thursday) I am ordering the Ryzen 1300X for my new build.. I would also need motherboard and RAM.. any recommendations please?
Ideally I'd like a ITX board as I'm downsizing to the Enthoo evolv ITX, not sure if AMD have that size.
Thanks
You should check the HCL to make sure the RAM works. Geil do AMD-specific RAM:
My basket at Overclockers UK:
Total: £164.20
(includes shipping: £8.70)
Agreed, the 3200MHz kits are still very hit and miss.
But the 3000MHz kits are cheaper, very little gains to be had if on a budget, and will usually hit the 2933MHz using XMP with the latest BIOS/AGESA release.
There's still an element of pot luck (members have same boards same memory but differing results) but the TEAM Group Vulcan kits usually hit 2933MHz with Gigabye's latest BIOS releases - on the Gaming 3 Mobos. I would hope their new ITX boards will be equally slutty...
