Permabanned
- 6 Sep 2011
I want to take some pics of my build but thought ill do a quick clean first. while i was in towi thought i may aswell purchase some compressed air.
i expected ****** to be expensive... however they cannot justify selling a small can of air for £16. i went to a small shop that does comp bits and thought they wud be selling it cheaper but they wasnt. was begonning to th ink that may be the value somehow.
quick search on the net found it at £2. shops that overprice items like that shud be ashamed.
99p a can, doesn't last long, maybe about 2 minutes of continuous use but at 99p a pop it's cheap. 1 can is enough for 1 good clean I find it though. As another guy said, spray away from computer first to clean any liquid in the pipe, and DO NOT SPRAY UPSIDE DOWN OR TILTED! Always keep the can upright, rotate other components instead rather than the can, otherwise you'll spray liquid (I think it's nitrogen) directly on the components.
Never looked back.
