compressed air from OC'ers
Yes, thats what it's for, lol :D
It feels wet becaouse its so cold, it evaporates straight away but dont have the nozzel so close and you wont have that problem.
However, I bought a can once form a local PC shop and found it not to have enought pressure to get rid of some dust, so went back to manual dust removal :(
thanks,was a bit worried with the coldness of the stuff, so it's fine to use? sure? i don't wanna kill my graphics card or anything.
how much does this 400ml last you think?
LOL yeah will be fine, you wont freeze you cpu to death :p
And who knows how long it will last, depends on how much you use it and for how long, the size of the case, how dusty the case it etc......:D
I would suspect it wont last long, when I use my dads air compressor ot soon needs to start pressurising and has trouble keeping up.
thanks, bit pricey for a can of air thought, nevertheless cheaper than anywhere else.
Great stuff, or blow very hard.
Or invest is one of these...
:p
You may well laugh, but i'm looking at getting a small compressor for airbrushing, and that thought had occurred to me ;) (we've got a big one in the garage but it's far too big/noisy to use in the house).
No no no, i was actually being genuine :p
Have a similar one for spraypaint, and have a fine nozzle that i use when cleaning out the case, in the back garden of course :D:rolleyes:
Just dont leave it lying around when your mates are about, my friends managed
to waste half a can freezing stuff, pretty fun rock hard olives, freezing beer
and crackable rolls (which my dog ate after, luckly she didnt die).
I can't imagine why anyone would dust the case outside ;) (I nearly choked last time I cleaned the HSF on a machine).
Thrill, as long as you're not being silly with it the amount of propane/butane used as the propellant shouldn't be a problem (if you're really worried keep a window open, and don't smoke ;) ).
7l variable control compressor from B&Q comes with tyre inflator, gun nozzle for cleaning out pc's, spray gun and a nail gun.:D
Cost me £80 and is very useful for all things.
It's in a can, I don't control it (do I?)
