Compression compatability check (MIPS DFI)
2 Aug 2004
Buckinghamshire
Does anyone know if the MIPS DFI northbridge block (the one that fits P35/X38/X48) will take 3/8th ID 5/8th OD Bitspower fittings?
In terms of the blocks tapped holes being too close together?
No, they are pretty right next to one another. Two Danger Den high flow 1/2" fittings pretty much nearly touch and need to be tightened at odd angles to get grip.
