- 26 Dec 2013
- 404 Not Found
In a lot of the builds I have seen with flexible hosing I notice most people seem to use barbed fittings instead of compression fittings. Is there any particular reason for this? Are compression fittings more prone to leaking than barb fittings?
Also, If I go with barb fittings, would I be better off using 1/2 barbs with a 7/16 tubing?
