Compression fittings
You need a joining ****. But I don't know if when tighened, it you will give you a 'U'
Two 90 degree bends like that will be a major flow killer btw. Why not just use a metal U with your tubing inside (to stop any Kinks if it really needs to be that tight)
I use compression fittings, how tight does the U need to be, if you have a few inches then a plastic coil spring might do the trick.
I've never needed a full U bend like that, and my PC is small, the right angled bends do swivel so I usually use a loop, swivelling the fitting to suit. Not pretty but works.
Any chance of a piccy or drawing?
