- 3 Nov 2009
Hi,
I bought these compression fittings and tubing, (as overclockers bundle packages)
TFC Compression Fitting G1/4" Thread 1/2" ID/3/4" OD - High Flow
http://www.overclockers.co.uk/showproduct.php?prodid=WC-011-FO
Masterkleer 7/16" Tubing
http://www.overclockers.co.uk/showproduct.php?prodid=WC-026-DD
The tubing fits real tight over the fittings (using boiling water to soften pipe) but the screw part is too wide to fit the pipe making it useless! Its so tight it doesn't leak but am worried over time the pipe will expand and then maybe develop a leak without it being clamped to the fitting. Has anyone had any experiance with this?
Also the thread on the fittings are worringly short. Of the 6 I bought 4 had left over metal thread inside the fitting which was loose but had to be broken off! Not something you would want running around your water cooling system and pump! I only just noticed it in time too!
