I ordered some of these: 16/10mm & 16/11mm compression fittings - black nickel and some XSPC 7/16" ID 16mm OD tubing. Apparently they are compatible, but I can't see how. The tubing is a loose fit on the 'barb' part of the compression fitting, and the union nut doesn't compress the tubing in any way, so I can simply pull the tubing straight back out.
According to my measurements, the tubing is a perfect 16mm OD, so presumably the compression fittings require 16.5 or 17mm OD tubing or something?
Any ideas before I get on OcUK's back?
Also noticed the packaging was a little sub-standard - opened the box to find a good amount of 'air space' and my NZXT cables rattling around, as well as my new GTX480 waterblock...
Come on OC!
Oh, and I also tried some 7/16 Masterkleer tubing I have, and that was no better, neither was some different XSPC 7/16 tubing. 1/2" is too big in both ID and OD, so what these fittings are designed for I have no idea...
Come on OC!
