hi guys,
Finally got all the base components for my watercooling rig:
My next step is the tubing and fittings. Now to be honest I was thinking of getting bitspower fittings mainly for the aesthetics, but at £8+ a pop I really couldn't justify getting them at least, unless they are worth it.
I do want to stick to compression fittings, mainly for the aesthetics, but I was just wondering if there was any particular performance issues/enhancements in getting standard compression fittings over say the branded bitspower fittings.
Would I be just fine getting the standard £2.50 fittings in terms of performance/reliability or are the branded enzo/bitspower/xspc fittings really worth the extra cost.
I spotted the XSPC fittings:
XSPC Coin Fit G1/4 to 3/8 ID 5/8 OD Compression Fitting
@ £2.50 each but I'm just wondering if there was a catch to seeing a branded set of compression fittings for so cheap.
Any advice guys?
Thanks in advance!
Any advice guys?
Thanks in advance!
