Computer About To Die?
16 Oct 2005
Poole
Hey guys I need to make this as quick and short as possible as my computer or rather my SSD is about to die I think! The rig is the Ultima Envy v2 which I purchased from here last year and everything has been fine up until today. Games have started running super slow and now there is a really horrible intermitted grinding/clunky noise coming from in the case. Also Windows is taking minutes to load up instead of a few seconds, can't view any documents etc as everything is so slow :(
Any way I can test just to be sure before I get hold of OcUK tomorrow?
Thanks.
Your SSD won't make noise.. :s
Get CrystalDiskInfo to check the SMART stats of HDD/SSD, it'll also warn you of any errors.
SeaTools for Windows and do a Long Disk Test.
What are your full system specs?
i5 4670k @4.5ghz
16 GB RAM
GTX 780
Windows 8
Samsung 250gb SSD
2tb normal hdd
Every time it makes the noise for a split second a little disc icon shows up next to the mouse cursor. Gonna open her up now and see if I can hear where the noise is coming from.
unplug it and try,it could be slowing everything down if its failing/failed ect
just get a new one their cheap
I had this once on a new build.
I would bet you didn't plug the power cable for the CD drive in properly, t had wiggled free a biter something to that effect.
