Computer build for architectural work
3 Feb 2011
Computer set up for running Autocad, Sketchup, Photoshop. Can you check the parts specified to see if there is any improvement to make.
CPU Intel Core i5-2500 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail [BX80623I52500]
Motherboard Asrock Z68 Extreme4 Intel Z68 (Socket 1155) DDR3 Motherboard
Memory Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
Graphics Card OcUK GeForce GTX 460 OC 1024MB GDDR5 PCI-Express Graphics Card
Hard Drive Western Digital Caviar Green 1TB SATA-II 64MB Cache - OEM (WD10EARS)
SSD OCZ Vertex 2E 120GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE120G)
DVD Drive Sony Optiarc AD-7260S 24x DVD±RW SATA ReWriter (Black) – OEM
Case Zalman Z9 Plus Tower Case with Fan Controller – Black
PSU OcUK Crusade 650W Dual-Rail High Efficiency Power Supply
Monitor Acer S243HL 24" Widescreen LED Ultra Thin Monitor - Black [ET.FS3HE.002] (or similar 24” monitor)
Keyboard,mouse and OS to be included as well
If you want to run programs like AutoCad really well, then you might want to go for more RAM. AutoCad is a right RAM muncher...
