Computer bulid advice/parts
4 Nov 2009
Port Glasgow
I will be buliding a watercooled rig soon and here are the parts im thinking on.
i7 Do @ 2.66 Ghz (hoping for 4.4 Ghz ) £165
6GB (3x2GB) Corsair Dominator 1280 cas 7-8-7-20 £186
Gigabyte GA-X58A-UD7 or maby the RE2/RE3 £175-£310
1000W Corsair HX £175
Black TJ07 with side window £250 (will be modding quite a bit of this)
Spinpoint F3 £57
NZXT Sentry LX Fan Controller £45
LG GH22NS50 22x £15
Creative Soundblaster X-Fi Titanium Fatal1ty Professional New Version
£105
1280MB ScanFX GTX 470 x2 £560
MNDPC (think thats it) sleveing kit £50
Cooling
EK-Supreme HF Full Nickel Universal CPU Block £60
Laing D5 Vario/Swiftech MCP655 Pump 12V £68
EK Laing D5 X-TOP G1/4 Rev.2 £23
Black Ice GT Xtreme 480 Radiator £90
Black Ice GT Xtreme 240 Radiator £60
Feser One Cooling Fluid x2 £16
Magicool Plexiac 150 reservoir £24
Tygon R3603 tubing (1/2"ID) clear £10
Sharkoon Silent Eagle 1000 120mm x2 £17]
Scythe Gentle Typhoon Fan 1850 rpm 120mm x6 £58
Koolance VID-NX470 x2 £195
MX-3 £6
All bitspower black fittings £60-80
i will be gaming at 1920x1080+
This is the max that i can really spend but if there are any better parts cheaper or more expencive i can maby up my budget a bit.
Thanks.
+1 for the 5970 and spending £105 on a sound card :O what you going to be doing ? lol ....
Or you just after a beasty pc...
also rkj done some nice work on his TJ07 should check out his thread on some idea's
