Computer Case for up to £70
25 Aug 2012
Hi all, I'm looking for good value and performance case. I would like to have good airflow and good cable management system there.
One problem is my CPU cooler as it is Scythe Grand Kama Cross 2. The air blows to the left side panel of the case so there MUST be some holes for the air get out of the case.
Thanks for help.
P.S. My budget is up to £70 but less is better :)
300R
One has a side window the cheaper version doesn't. With a 140mm fan at the front and a 120mm fan for exhaust it offers good airflow. Your heatsink isn't tall but the 300R can take taller coolers than the 200R
300R
Okey I'm going to order the one with window as its look better. :)
Thanks for help.
