Computer Case Thumb Screws
19 Feb 2008
Home
probably a stupid question but are all thumb screws the same size ?
im after 7 and have found some but not sure if they are all the same size.
part of me say's they are but not 100% sure.
Thread: 6-32 Length: 5/16 in (8mm)
will these fit a pci slot on a 800 d case ?
All have the same thread 6-32 UNC but the length can be different.
As for PCI-E slots, yes they will fit.
Actually, not all are the same! Some cases use M3 bolts.
They usually are 6-32UNC, but can sometimes be others. You can tell, as the 6-32 is a coarse thread, and M3 is a lot finer.
