Man of Honour
- 11 Dec 2002
- Darkest Norfolk
I'm trying to find a lamp or small sign that i can plug into a PC via USB and control via a simple API / interface.
Basically I'm looking to make a warning lamp for when one of our systems is down.... Anyone know of a cheap solution?
Cheers
Sam
Cheers
Sam
Just have an opto isolator or relay if your lamp is greater than 5v. Otherwise a LED with a series resistor will do the job.
