computer cover removal?
11 Jul 2009
Nice and simple, how do you remove the front cover from your case??
mine has these black pegs that seem to need to be squeezed in but getting your fingers around these is nigh on impossible. any help/suggestions??
I had a similar problem with a friend's case. I used a screwdriver with removable heads. I removed the head so it was basically just a little tube. I then pushed the pegs with it and they popped right off.
Hope that helps.
With considerable difficulty. Mine has six tabs that need to be pried outwards, three at a time. I've foolishly put radiators in the way. Thankfully the front rarely needs to be removed
From most of the tower cases I've seen, LianLi, Akasa etc, there is usually a gap under the front panel that you pull up (bit like opening the boot of car).
