So, I've been having these sporadic crashes the past ~month (ish) and I've not really any solid idea what's causing it. This is somewhat of a repost as (I) unintentionally derailed my other one with what appeared to be causing the crash however it was totally irrelevent hence posting again as I doubt people would revisit the previous.
I had problems with this system initially; the motherboard was faulty, and following replacing that I had tons of BSOD's (I'm sure some of you saw the thread on that), and ended up replacing the RAM after confirming it was faulty.
So, I say these crashes are sporadic because I can crash three times in one day, once in a week, or not at all for two weeks to suddenly crash again, it also happens at no particular moment given it has occured when my pc has been on for a long time, under load (gaming) and once when just idling on the desktop.
There's no BSOD's, no application hangs, no slow downs of any sorts before the crash happens, no motherboard beeps, no crash dumps, no indicator at all that I can see, so my first question would be, which pieces of hardware can cause a crash like this without producing any kind of error?
The crash is sudden, the system will just instantly freeze and I'll simply reboot and everything is fine.
I'm currently thinking it's the SSD as one or two people pointed it out to be the likely cause, however I want to make sure it couldn't be anything else before I contact ocuk about an RMA
Note that apart from this the system is running flawlessly, there are no issues with temperature, loose wires and whatnot.
My specs are below and I'm running Windows 7 64bit
Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor
Gigabyte Z87-HD3 Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Seasonic G series 550w '80 Plus Gold' Modular Power Supply
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
Corsair Carbide 200R Compact ATX Case - Black (CC-9011023-WW)
CoolerCooler Master Hyper 212 Evo CPU Cooler
Samsung 840 Basic 250GB SSD
MSI Radeon R9 280X Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card
