Recently my system has started freezing and it has become extremely annoying. Last night it happened after playing about 10 matches on Football Manager and I hadn't saved!
Basically the mouse won't move, the keyboard doesn't work, ctrl+alt+del doesn't work and the reset button doesn't work so I have to turn the power off at the back and reboot.
Here is my spec:
OcUK GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express)
Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Microsoft Windows Vista Home Premium 64-Bit Edition DVD
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2
Samsung SpinPoint F1 1TB SATA-II 32MB Cache
Any ideas as to what I should do?
I have tried to research the problem and thought it may be to with my hard drive. I found this advice on a different forum:
Thought the OP was suffering a slightly different problem this seemed to work for him.
I tried to do the same thing but I can't seem to find a disable command queuing option in the device manager.
Any help would be greatly appreciated as it's driving me nuts!
Thanks.
Here is my spec:
You'll need to turn off command queuing for the Samsung drives. With it enabled, under load the drives grind to a halt and freeze up Vista until you power cycle your computer - reset button doesn't do the trick.
From device manager you'll need to look at the Serial ATA Controller properties, find the right port your drive is connected to and uncheck the "Enable command queuing" option.
I had exact same problem with the pair of F1s I ordered. Crappy firmware I guess.
Thanks.
