computer freezing sometime when starting a video
23 Nov 2009
North Leicestershire
bit weird but sometimes if i go to a web page with a auto start video or browse youtube my computer locks up and i have to hard restart via the button on the case.
any idea what the cause could be, i thought maybe the ati/amd drivers but i've been using them a while and this only started happening a few days ago. :confused:
oh and event viewer only tells me kernel power which was me resetting the comp it tells me nothing of what caused it
I take it this is the system in your sug?
Have you tried running a stress test on your overclock? If not, try running a folding client or Orthos Prime for a few hours to see if you get the same result. test both CPU and blend. I'm wondering if your OC isn't as stable as you might think. If the test passes CPU but fails the blend, then you may need to apply a little more VDIM. Otherwise Vcore or NB.
No overclock is fine, i tested this yesterday IBT 20 passes on very high, and a 4 hour blend test all came back with no errors. Somehow only seems to be related to pages with videos on them.
it might be hardware accelleration in flash, right click on the video and there is an a settings / or option, in there its a tick box....
thats assuming its a flash video...
