Computer freezing when HDD installed.
9 Oct 2008
Somerset, UK
Hi, today i booted up my PC, and all seemed well, then i clicked on that start button, the computer just stopped working, it didnt crash, the clock was still moving and i could still use my mouse, but i coulnt click o anything or open the task manger. I started in safe mode, worked fine, then back into windows, same thing happend, it only happens when i click or open something. (Btw, O/S is on SSD, and Data on HDD)
So I then removed hardware seeing if anything was causing the, i remove the HDD and the PC works fine.
I then proceeded to open in safe mode with HDD and run a error check, everything was fine,
I decided to reformatt my whole PC SSD too, installed everything and it was running fine over the last week, then coming back home tonight, i boot up my computer and the same thing has happened again.
Any ideas what is causing this or how to fix it?
