computer freezing :(
21 Dec 2009
Huddersfield
Hey people,
back when i had vista every so often my computer would freeze and i had to reboot no matter when i overclocked or ran it on stock...
now been on windows 7 for a few months and its starting to happen again, seems to happen allot when listening to music on youtube :(
had my processor today at 3.6Ghz as i have had for over a month now and wehn i ran 25 loops of intel burn test it was perfect with hardlyany increase in Gflops,
reverted back to default settings today and ran IBT to getthese results :(
anyone care to offer advice quickly?
should i reseat cpu cooler? what tests can i do on my hdd, psu ram?
my HDD has also started clicking every so often (not every day) and yday by screen was flickering on and off for a few secconds.
please help
Have you tried using the onboard graphics to see if the GPU is at fault? How about malware? Download Panda antivirus on trial, it works really well to find these things!
got kasparsky itnernet and found no issues, why should i try onboard graphics?
was expecting more help :(
You often get this problem when there are GPU problems. Also, keep an eye on the CPU and RAM usage, see where it is when it freezes. (if you open task manager, you get a tray icon showing the CPU usage, so you dont have to have it open all the time)
Also, how many processes do you have running? Bump for solution
computer freezing due to my graphics card :S??
cpu and ram usage is allways average really when it crashes i am doign the littlest of tasks, right now typing thismessage i ahve 1% cpu usage.
2.6Gb or ram left to use at this moment in time (i have 4 gig ram)
when computer freezes i can't get task maanger open its comepletely none responsive :(
current cpu idle temps =
37
31
42
42
Q9550 at stock speeds / volts etc
ty
Wow, got me! If you want to see the overall cpu usage when it freezes, open task manager, then minimize it. You will get a tray icon at the bottom with a small graph showing current CPU usage. So when it does freeze, look down there and it should be frozen at wherever it was when it froze.
Maybe someone else can help here?
@gundog, not able to see task manager when computer is frozen its 100% none responsive.......
psu = Coolermaster 700W modular
how do i check voltage stability on various lines? what are varios lines?
i was honestly expecting more help from this forrum :(
Use this software:
http://www.cpuid.com/hwmonitor.php
The lines are the 3.3V,5V and 12V. If the lines deviate more than 5% from the indicated values when your CPU and/or GPU are under load then you have a problem.
I would also use Memtest to check if your RAM is the problem:
http://www.memtest.org/
I would also try Spybot and Ad-Aware to check for any spyware on your computer.
Not graphics related... doh
plenty of power
stable overclock
The only thing I picked up on earlier in your post was the hard drive clicking which is not a good sign. Suggest you run a HDD diagnostic program. Bad sectors might cause system freezes, but I'm not absolutely sure but it's a starting place at least :(
Use this software:
voltages hardly increased, no where near 5%
unable to see voltage for gpu with that program just shows temps
memmroy testo program won't open on windows 7 :S
