Computer from 2012 upgrade advice
4 Jan 2012
Hello all,
I was about to buy a bigger SSD but figured it might be a good opportunity for an upgrade. My current PC I built since 2012, actually has done me good.
Processor: i5 2500k 3.3GHz
Graphics: HIS 6950 IceQ Turbo 2GB
Motherboard: Asrock Z68 Extreme4 Gen3 Intel Z68 (refurbished, i stupidly fried the first one by accident)
RAM: Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz
PSU: Corsair Enthusiast Series TX 850W V2 High Performance '80 Plus Bronze
I have 2 monitors, quite happy with gaming at 1080p as long as I hit 60FPS. I was thinking about upgrading the graphics card to a 1080 ti and play a couple of VR games (I can borrow a rift/vive from work). I haven't overclocked anything. I tried looking into but must admit it is scares me as I might mess something up. I've seen other people with a 1080ti and 2500k and being able to play VR but they had their processors overclocked; would I be able to play without overclocking?
If I do end up buying the graphics card, I could incrementally make upgrades as opposed to upgrading in one go. I'm up for recommendation for 1080ti, although one of my monitors is DVI-D and the other is currently connect with VGA (can do HDMI)
Thanks
edit: forgot to add power supply
As above.
And with the money saved, from not buying a 1080TI, strap on a better cooler (if you haven't already) and clock that 2500K to an easy 4.3/4.5GHz. It will allow the GTX 1070 to breath more - giving better FPS/performance.
And with the other savings double your memory to 16Gb - ideally 2 x 8GB - and sell you 8Gb sticks.
You will still have cash left over not buying a TI and better performance too within games.
Haven't really thought about upgrading the cooler, but now that you mention it it's not a bad idea. The one I have is pretty loud. Which one should I get?
Also, can I put off upgrading my RAM? Do I need 16GB?
What's your case size? You need to check cooler maximum height.
But these are two great value coolers:
My basket at Overclockers UK:
Yes, of course. You can get by with 8GB - but know that a lot games are utilising/needing above 8Gb now.
But you can certainly get by with 8Gb if needed.
I have a Corsair Carbide 500R Midi Tower Case, pretty sure the ones you have mentioned will fit. How quiet are they? I got one of the Akasa venom voodoo and it's pretty loud.
You already have capable cooler - you would be after a Noctua, Phanteks or be quiet to get the performance you want plus relative silence.
BE Quiet! Pure Dark Rock 3 is a very quiet cooler, but then again for the price the Evo 212 is not that far off and its a hell of a lot cheaper.. :)
I run the Evo 212, its very quiet and keeps my i5-3570K under 40c even under load.
Under what clock and voltage?
As they are quiet if cooling CPU at stock/volts - but they usually become audible when countering higher clocks/volts under load.
I suppose I could buy the fans only. Just got back home and checked my CPU cooler, it had those rubber mount things that's keeping the fan to the braket. I guess I'll buy the Noctua then since I remember a lot of people swear by them
Currently running a 4.2ghz overclock with 1.31 vcore. Under max load, you can barely hear the fans, and temps dont go above 72c.
EDIT: I had a little look last night and I do have an additional fan fitted so operate a push/pull on this cooler.
Is this gaming load?
At those volts/clock you won't be stressing the EVO - and with the second fan it won't be spinning at full speed - if the 40 degrees under load is under normal load (not synthetic benching).
And at low operation the fans are quiet. It's a great, classic cooler for the money.
Is the 72 degrees under synthetic test load?
