Computer/Hard Drive trouble
Permabanned
15 Jan 2006
The family computer downstairs is really old (approaching a decade now :D) and I think it's died and I need a little help with a couple of issues. Let me explain what has happened to the computer first of all.
Although it's as slow as a dead snail, the family PC has always been reliable but recently (in the last 3 weeks) it started restarting a lot by itself at random times. This wasn't too much of a problem because my family only use the computer sparingly, to check the odd e-mail/facebook/ebay auction so a crash here and there wasn't much of a problem.
However, yesterday when my dad tried to turn the PC on it got to the part of the loading up process where you see the Windows XP logo screen with the scrolling bar below it, stayed on that for about a minute and then it just restarted itself, started booting up and got to the same part of the load up process before restarting. It does this everytime, and trying to load the computer up in safe mode makes no difference.
The biggest concern of my parents is that there are a lot of photos on the computer they really don't want to lose so I am doing my best to recover the pictures somehow.
I figured a good way to do this would be to take the hard drive from the family computer and put it in to my computer so I could move all the pictures from that hard drive to mine. However, I'm having some problems. When the hard drive from the family computer is connected to my computer it takes ages to boot up in to windows, and all the time it's doing this the hard drive from my family computer is grinding and churning away. When I've finally got in to Windows (I'm booting in to windows from my hard drive, not the family hard drive obviously) if I try clicking 'My Computer' the computer hangs, I get the hour glass icon and it takes a good few minutes before 'My Computer' section opens and I can continue. My PC detects that the family computer hard drive is connected but when I double click it I get the old churning, hour glass and hang syndrome for a few minutes until it finally tells me that the (D: ) drive is not formatted and asks me if I would like to.
I'm really confused, what is going on? What is with all the hanging and loading while the hard drive is connected to my PC, and when I double click it to try and browse the hard drive why does it tell me the hard drive is not formatted?
Any help would be greatly appreciated. Thanks.
as its a primary hdd from another pc i would guess its in its master configuration, does it appear to be in a slave setup in this other machine ? you would have to make sure the jumpers are in the correct configuration.
i would boot to dos and see if you can read it from there. if you can , there you will be able to copy files from and to different hdd's using simple commands.
or its likely that after all these years , its finally packed in. worst case scenario for you , but possible.
any clicking or strange noises coming from the hdd?
hey dude, thanks for the reply.
i've made sure that the hard drive is in slave mode but it makes no difference.
how would i go about booting from dos, and what commands would i need to use? is there a webpage with them on or something? :)
and no strange noises from the hard drive, as i said just a lot of grinding cause it's so old.
