computer hardware failure rates.
19 Jun 2004
n/east-the toon
Do OCUK think these statistics are about right, judging by thier failure rates on computure hardware failure.
Guru3D - http://www.guru3d.com/news.html#12745
The data originates from a large French e-tailer, it covers returns created before October 2010 for hardware sold between October 1, 2009 and April 1, 2010. The brand failure rates are compiled using a minimum sample of 500 sales, while model failure rates are calculated using a minimum sample of 100 sales.
In the motherboard market there doesn't seem to be a lot of difference between manufacturers:
Gigabyte 2,33% (contre 2,36%)
MSI 2,44% (contre 2,54%)
ASUS 2,49% (contre 3,05%)
ASRock 2,71% (contre 2,21%)
The memory market shows quite a different story, especially OCZ dropped the ball as its failure rate increase more than doubled compared to the last report.
Kingston 0,30% (contre 0,37%)
Crucial 0,93% (contre 0,78%)
Corsair 1,41% (contre 1,66%)
G.Skill 2,73% (contre 1,53%)
OCZ 6,76% (contre 2,76%)
The HDD is likely one of the most critical components in your computer, in this category Maxtor received the best ranking:
Maxtor 1,04% (contre 1,73%)
Western Digital 1,45% (contre 0,99%)
Seagate 2,13% (contre 2,58%)
Samsung 2,47% (contre 1,93%)
Hitachi 3,39% (contre 0,92%)
SSD failure rates are also listed and although you usually hear that SSDs are more durable than HDDs the numbers show a different story. Only Intel SSDs seem to score significantly better than HDDs.
Intel 0,59%
Corsair 2,17%
Crucial 2,25%
Kingston 2,39%
OCZ 2,93%
The slightly worrying thing about those stats, is that certainly for things like HDD's and memory some of the manufacturers are pretty much the automatic first port of call in event of failure (I always RMA drives to the manufacturer unless it fails in the first couple of weeks), so the true failure rate for some of those items is almost certainly higher.
How many are failures through misuse or user fault and how many are DOA products!
Just browsing on here recently turned up several cases of people screwing the motherboard directly to the case....
