Hello all
I've got a abit kv8 max board with a AMD 3200+ 64 ( 3 years old now at least) 1gig of ram
I've been having a few problems with the computer over a period of time now.
Last night i switched it off after using for a few hours everything was fine.
Went to boot it back up later on and it just hangs on the the blue screen that says Windows XP and has the logo just before going into desktop.
I've tried safe mode no good also as it does the same. Switched everything off reseated my memory unpluged my SATA drives still no good.
When i unpluged my SATA it then could't detect them when i plugged them back on I did this with the power off before any says anything
A also reset the CMOS and took the battery off the motherboard.
I had a error i'd never seen before also at one point that i'd changed cpu or CPU was unusable?
But thats now gone and it boots up again to the screen it hangs on.
I've no idea why it's done this or how to fix it?
Really could do with some advice please.
Thank you..
Thank you..
