Computer locks itself every minute or so. Help!
10 Sep 2008
Bangor, Northern Ireland
Hey guys, just wondering if anyone had experienced anything like this before. Basically my computer will lock itself and go to the windows logon screen at strange intervals. Its our work server (so quite worrying) and its on all the time. there would be times when i'd come in in the morning to find it locked (everything is set to be on constantly so im not a muppet and havent turned off the option to lock it :)) but since this morning it seems to go into bouts where it will lock itself, i will unlock it, then 30 seconds later it will lock itself again. This will go on constantly for about an hour then it will ease off for a few hours then come back as bad as ever.
Is this a virus or something similar? Ran a virus check but nothing was found and my googling skills havent brought up anything either.
So Anyone got any ideas??
Thanks
Have you checked through the event logs? Something that's locking the system that regularly should be fairly easy to pick out in the system or security event logs.
